OID code Monitoring Tthroughput for SSID WLC
loffreda
Hi Team ,
I need to monitoring the Tthroughput of all my SSID , i have WLC 5508 and  I use third party software PRTG . Do you Know  the OID code to do this.
Try taking a look at this site:
https://www.cisco.com/c/en/us/support/docs/wireless/3504-wireless-controller/214452-monitoring-cisco-aireos-wlc-via-snmp-usi.html
Also on the Cisco.com software download there is the MIB packs:
https://software.cisco.com/download/home/282600534/type/280775088/release/8.3.141.0
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hi Haydn,
thanks for the feedback , I look the first site there are some OID but in the specific my request is not present , i surf on the internet but I have not found anything so I'm thinking it is not sure It can be done. The OID present on the site it is very interesting and work in my third party software and thanks you , so I wold ask you if you have some others information with OID code i resolve my issu in the specific the throughput.
Thanks and a Good Day
