Option to Air-Ant2566p4w-r
Darrells
Hi, i am using the above mentioned antenna for warehouse services but need to knkw if there is alternate offering to this that i can use if i can’t get the 2566 in country, i was thinking the Air-Ant5170P-R would do it even though it is just 2 port but i only need to test on 5ghz
Ric Beeching
Level 7
Level 7
Darrells - What APs are you planning to use with the antenna? If you want to use 5170 it must be compatible.
Ric
Please rate helpful / correct posts
