10-31-2013 01:25 AM - edited 07-04-2021 01:11 AM
Anybody knows that the Cisco outdoor antennas (for example: ANT25137NP-R and ANT2544V4M-R) made of UV resistant polycarbonate?
Janos
11-05-2013 06:00 AM
Please check the below link:
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant25137npr.pdf
11-07-2013 01:43 AM
Hi Angeel,
I checked it many times but I did it again. Could you point me a word or sentence what means that anybody count with the UV problem?
Janos
11-05-2013 02:03 PM
Wouldn't make any difference if it's not since these antennas are designed for installation on Earth. If, however, you plan to install antennas in Mars, where UV and Gamma radiation is high, then the question is relevant.
11-07-2013 01:46 AM
Hi Leo,
When the Customer ask from you a Declaration of Comformity that this device is an UV resistance I will quote you sentences.
11-15-2013 03:27 AM
Generally , for outdoor Antenna, you need to bother about the cables / connectors , if they are UV resistant, However cisco wireless outdoor products are already UV resistance.
