Outdoor LTE antenna options
John Torkos
I'm using a Cisco 1941 router and want to use an external LTE outdoor antenna. It appears quite simple actual but what I don't understand is why the Cisco Product Configuration doesn't have an option for a "mast mount outdoor omni-directional antenna"? Also, would I not require lightening arrestor? Under the 3G module i can select the Cisco 3G-ANTM-OUT-OM & Cisco 3G-ACC-OUT-LA so what's going on here. Perhaps the Cisco Product Configuration doesn't have those parts in Canada? Does any know?
Only options available in the Cisco Product Configuration:
EHWIC-4G-LTE-CA
ANT-4G-SR-OUT-TNC
4G-CAB-ULL-20
0 Replies 0
