Outdoor Mesh
Ghassan Awadallah
Community Member
Is it possible to connect  1552  as MAP to 1532 as RAP or  vice versa ?
Stephen Rodriguez
per :
http://www.cisco.com/c/en/us/products/wireless/outdoor-wireless/index.html
the 1530 "interoperates", but none of the Data Sheets call out how.
I would take that to mean it can be a MAP to a 1550 RAP.
but I'll keep digging
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Yes. It will work.
Thanks George ,
did you test it before, or read it on cisco Documents ?
you are right Steven, nothing in the data sheet, also  "interoperates" is vaguely word
