09-30-2016 07:34 PM - edited 07-05-2021 05:54 AM
Hi!
One of my customer want me to install and OUTDOOR NEMA(enclosure) for cisco AP 3702 but I can´t find the Part number to order it!
Can someone tell me if there is a part number? I have found http://www.terra-wave.com/cisco-3702e/http://www.terra-wave.com/cisco-3702e/
but obviously is not cisco.
So i guess the question is: cisco cell this Items? if so where can I find the part numbers?
Thanks in advance
Solved! Go to Solution.
10-01-2016 06:21 PM
You are correct, Cisco doesn't make them. They recommend one of the following vendors in this document:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html
Third-party sources for NEMA type enclosures include:
10-01-2016 06:21 PM
10-03-2016 09:41 AM
Hi!
Thanks a Lot
