Packet drop when clients moving from one Access point to another
Angus Bishop
HI  All ,
I am new to wireless . I am using  WS-SVC-WISM-1-K9  wism module and using 5 Access points . When my clients are moving from one access point to another we are getting packet drops .
Kindly anyone suggest me what all configuration i need to verify on the controller  for Proper client roaming so that i can resolve my issues..
Please let me know in case of any explanations requiered .
Thanks  in Advance !!!
Angus
Nicolas Darchis
For radius authenticated SSIDs, you need WPA2-aes or wpa1-tkip-CCKM. It depends on what the client supports.
For pre-shared key, any WPA should be decent enough for roaming speed.
If you're on WEP ... no comment.
If you covered the above point, check if it's not a coverage problem. If the 2 APs coverage zone are not overlapping there will be a hole where you don't have signal and logically will have packet drops.
