Packet trace on Dot0 interface
py.lebreton
Community Member
We are using Aironet 12xx AP's and I would like to know if it is possible to do a packet trace in CLI mode.
Something like a tcpdump on the dot0 interface in order to see all in/out traffic to the wireless.
It would avoid me a 400km travel to the site for a wireshark/airpcap capture ...
Many thanks in advance for any suggestion.
PY
dancampb
Level 11
Level 11
There is not a tcpdump type of output on the AP but depending on what type of traffic you are looking for you may be able to see it with some of the dot11 trace print debugs.
Thank you for the information, can you please advise on the dot11 trace commands that you tell ?
