packet tracer 1.1.6 cellphone not tethering to pc
SaraMI
HI
In packet tracer 1.1.6 cellphone not tethering to pc
I have followed all instructions, but the last part is not tethering to cellphone to pc.
Please see attached text file for instructions.
Thank you.S
Archelles
In the Smartphone / Configuration tab, and select settings.
Look at the bottom and and check Cellular Tethering Bluetooth.
Then go back to User laptop window and click tether. It will be able to connect.
NetworkDave
Hi Sara,
Please send your PKA or PKT file for review.
Archelles
DING!!
Thanks. Works
