PC to PC blocking will connecting to same SSID
We are having Cisco 5760 WLC. I want to block PC to PC connected to same SSID (intra VLAN blocking). Please let me know how i can block PC to PC connectivity on PC's connected to the same SSID.
Sandeep Choudhary
HI,
You need to use this command under WLAN config.
wlan XYZ <WLAN ID> XYZ
client vlan <VLAN ID>
peer-blocking drop
no shutdown
http://www.cisco.com/c/en/us/support/docs/wireless/5760-wireless-lan-controller/200071-Wireless-Converged-Access-5760-3850-365.html
Dont forget to rate helpful posts
Thanks, will test this and update
