PCM350 card DOS installing problem
admin_2
Level 3
Level 3
I have installed a PCM350 card into my NEC
laptop running MS-DOS operating system v.6.22.
When the driver starts up, shows the following
message:
Card services not present, trying 82365.
Driver resources ---> IO Ports: 0300-033f
IRQ: 0B Memory: D000
Radio configuration failed
Invalid parameter for IRQ
CSCPKT failed to load
I have tryed to start up the driver with card
services installed, but the response is the
same (of course I didn't get the 82365 message)
I have also tried to start up the driver with
all allowed vectors numbers (from 0x60 to 0x7F)
but the result is the same.
I think I have problems during the loading of
the driver, but it seems the I/O and IRQ
resources are appropriate.
Could you help me ?
Best Regards
/Alessandro
kmarrero
Level 4
Level 4
Try to reload the driver again using the following guideline.
http://www.cisco.com/warp/public/102/wlan/DOS-Aironet.html
