Peap Authentication Problem
k.mahmood
I have a difficult situation here. I am running ACS 3.2 on W2k with SP4.On same box we have our Certificate Authority as UAD Starone, We have Enterprise Root CA on our W2k Active Directory DC.
Client side, having XP SP1, Linksys Wireless card.
Ap1200 with latest 12.2 (13)JA3. Setting are fine.
I am following the guide lines from the latest updated paper link as below:
http://www.cisco.com/en/US/customer/products/sw/secursw/ps2086/products_configuration_example09186a00801df0e4.shtml
But the errors which am getting are
on Ap1200 logs Station 000c.41af.9511 Authentication failed.
and on Acs failed Attempts Active.csv are Message Type: BAD request from NAS
Authen-Failure-Code: Invalid message authenticator in EAP request.
I am very much upset. I have checked all the trouble shootings but no success.
can someone will be able to help me or at leat tell me that where is my problem resides.
I donot know whther my problem is in Ap1200, Client, or ACS 3.2.
regards
Khaleefa
murabi
Level 8
Level 8
The ACS error message suggestion a mis match in the radius Keys, better check your keys.
murabi
Level 8
Level 8
