Cisco 1100/1200 802.11g upgrade kit
dsidley
After trying this upgrade in both a 1200 and 1100 series AP I am extremely disappointed in the througput I am getting.
Even when set to "G-only" and operating in an area which is free from any other RF traffic I can only achieve 20.5Mbps.
Perhaps I have missed a setting in the config somewhere... Anybody else experiencing poor g-only performance on this 802.11g upgrade??
Dave S.
mchin345
Level 6
Level 6
Did you try reseating the specific .11g radio into the chassis? The radio itself could be a suspect. Once the radio is reseated it would be very useful to restore the AP to default configurations and then reload your non-default to get a clean slate.
Is there any info or links on how to accomplish the b to g upgrade on a 1200 AP? Cost?
Thanks.
http://www.cisco.com/en/US/partner/products/hw/wireless/ps430/products_quick_start09186a00800c7515.html
The instructions in this doc are pretty much the same for upgrading from b to g. This doc refers to removing or replacing b. You will get all the docs you need when you purchase the radio.
