PEAP authentication problems
stefaanbolle
Community Member
I configured a Cisco AP 1200 IOS with PEAP.
Hereby the AP Config:
aaa new-model
aaa group server radius rad_eap
server 192.168.4.58 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 arp-cache optional
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 184 key 1 size 128bit 7 xxxx transmit-key
encryption vlan 184 mode wep mandatory mic key-hash
encryption key 1 size 128bit 7 xxxxx transmit-key
encryption mode wep mandatory
broadcast-key vlan 184 change 3600
ssid test
vlan 184
authentication open eap eap_methods
authentication network-eap eap_methods
world-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
station-role root
dot1x reauth-period 1800
dot1x client-timeout 1800
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.184
encapsulation dot1Q 184
no ip route-cache
bridge-group 184
bridge-group 184 subscriber-loop-control
bridge-group 184 block-unknown-source
no bridge-group 184 source-learning
no bridge-group 184 unicast-flooding
bridge-group 184 spanning-disabled
interface FastEthernet0
no ip address
ip accounting output-packets
no ip route-cache
speed 100
full-duplex
interface FastEthernet0.3
encapsulation dot1Q 3 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0.184
no ip route-cache
bridge-group 184
interface BVI1
ip address 192.168.4.98 255.255.254.0
no ip route-cache
ip default-gateway 192.168.4.3
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
radius-server local
radius-server host 192.168.4.58 auth-port 1645 acct-port xxxx key xxx
radius-server timeout 120
radius-server deadtime 1200
radius-server domain-stripping
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 protocol ieee
bridge 1 route ip
bridge 184 protocol ieee
W're using a Cisco Wireless client adaptor with the latest ACU version fully installed and configured my client for PEAP. I also configured the Windows XP network settings appropriately.
The RADIUS we are using is a Cisco ACS 3.2.1. We used a Microsoft certificate for the server that we issued ourselves.
Without configuring security, the client can associate with the AP, but when we enable PEAP and I open the ACU status screan, the client associates with the AP, but canot authenticate successfully. Status hangs on 'autenticating'. I don't see any traffic to the RADIUS server.
Who can help us?
Thanks in advance!
6 Replies 6
Not applicable
Try installing the latest image for the AP 1200, if you have not already done this
stefaanbolle
Community Member
Thanks for the reply!
We're already runing the latest image version of the AP.
steve.deal
Community Member
1. You do not want to use windows to configure the adaptor if you are using ACU.
2. Make sure you install the certificate on the client machine.
I have had better luck using the XP client for peap than ACU.
Not applicable
I know this doesn't help, but I have exactly the same problem and symptoms as your are experiencing.
I would be happy to hear about your resolution. I suspect that we will have better luck using the MS supplicant rather that the Cisco supplicant, but I have not been able to try this yet.
I will inform you if this approach works.
jczaplewski
Community Member
Many things could be wrong unfortunately, so I'll list a few that I've had to trudge through in the hopes they help:
1) You're using ports 1646/1645 for RADIUS. Those are the older ports. Newer servers use 1812 (I think 1813 for accounting, I'd have to verify). Ensure your server is listening on 1645 as you have defined or you wont get any authentication.
2) Turn on dot11 debugging. The nice thing about new IOS APs is they give you the ability to see if you're even hearing your client. I'm still learning to use this tool but I use "debug dot11 aaa dot1x all" to see who's talking and when. The output is of course cryptic, but it's nice to see the output.
3) Lastly, once you're talking to the RADIUS server, use it's logs to determine the output error. I've found that with PEAP, depending on the client I use (I use a FUNK radius server, and FUNK Odysee Clients - thank you Cisco for ignore CF form factor wireless cards for 4 years ;p), the inner authentication protocal version 1 or 2 is the complaint from the RADIUS server.
I just opened a TAC case on this one whereby I have already installed the latest client, made sure PEAP is installed, had the latest WAP image, network security setup on the ACU as per the documentation to select the "host base EAP(802.1x) and select dynamic wep, then turned on debug options on the WAP to see the communication between the client and the WAP:
debug radius authentication
debug dot11 aaa dot1x process
debug dot11 aaa dot1x state-machine
Guess what... there is no communication between the client and the wap for authentication. You can see association and even get an ip address from dhcp but...
The advise as per the TAC engineer is to put in a Static WEP key for now and you should get the communication going. They have already noticed this on some calls and have not seen a bug case # assigned to it. They will be working a fix on the next release. Once you do that you should see the Raduis and 802.1x communication going on.
After doing this I can then concentrate on why I am not getting PEAP authenticated on our Funk Radius EE Server v4.7.
The other thing...remove the "authentication network-eap eap_methods" when you are doing PEAP. You enable that for LEAP so you have to create a different vlan for that.
I use 1812/1813 for the radius server.
🙂 Ed
