PEAP-GTC - AP1200s - ACS and passcode failures
socket2000
We're using AP1200's with PEAP-GTC and a Radius server running ACS v3.1 with a RSA Ace Securid server for authentication. The problem that we have is that the passcode failures aren't passed back to the wireless client for the Dell TrueMobile 1450 card (latest drivers). If the user enters an invalid password then the authentication box goes away as if the authentication was successful. In the background ACS logs a failed auth attempt every 5 seconds and the RSA token is very soon completely locked out. If the password is correct then the connection works fine and there are no problems. Here's a line from the ACS failed attempts log
30/08/2005 15:53:27 aplavs02 Authen failed userxx 30 Minutes 0090.4bdc.3309 External DB auth failed 463 10.221.xx.x userxx
There don't seem to be any clues there.
I haven't got as far as testing 'next token' and 'new pin' modes as anything that's not a pass results in the same scenario.
Does anyone have this setup working already ?? or any clues as to where to start looking.
Many thanks
Steve
0 Replies 0
