PEAP Machine Authentication fails
colin.lynch
Level 4
Level 4
Hi All
I am using PEAP with the following setup
WLC 4404
ACS Solutions Engine 4.01 (self signed cert)
Windows AD database.
PEAP user authentication works fine.
The issue is, I need to only allow machines which are in AD as such I have configued Machine authentication.
However this is failing with the below log.
host/wks1.lnd.uk Authen failed EAP-TLS or PEAP authentication failed during SSL handshake
I have configured the ACS for PEAP machine auth in all required places and on the client. I have read lots of info saying I need to configure AD to allow Machine Authentications, and cert auto enrollment etc.., is this the case and if so whats the easiest way to do it?
Thanks in advance
Colin
18 Replies 18
removed - wrong thread...sorry
spirotsares
I'm in the process of deploying the same setup. Would I be able to get a copy of your diagram @
mrspiro@gmail.com
I am also trying to implement the same solution, would I be able to get a copy as well....farhan.mirza@gtsi.com..
Colin,
If you're still checking this board, I would appreciate a copy of this diagram as well.
ybaglakolov@gmail.com
