PEAP + SSL + WLC WCS issue
sudip.acharya1
We are trying to activate PEAP for our BlackBerry users but according to Blackberry support, their devices will not accept a PEAP connection unless there is a rd party SSL cert on the WLC/WCS server.
How AND where do we enable our Verisign cert so that Blackberry devices can connect?
Our WCS is running on Win2003 with IAS.
Thanks in advance.
dancampb
Level 7
Level 7
The cert needs to be on the Radius server, not the WLC unless you are doing local EAP.
I got that part but how can the cert be applied if wcs is running on a stripped down version of apache? On the server, i do not see the normal Apache services that one would expect to see.
Are there any directions on applying the cert. on such a server?
a.nenni
I sent you a private message...
