PEAP
mukeshk
Community Member
I have configured Peap configuration and using IBM laptop.I have configured laptop to ask password every time but it is storing password and using as a default authentication. How to get rid of the password that laptop is storing.
segopala
Hi Mukesh ,
Which Wireless supplicant are you using
if you using zero config : then you need to go to the registry and delete the cache file
the path is :
HKEY_CURRENT_USER\Software\Microsoft\Eapol\UserEapInfo
becareful while playing with registry
