WLAN Lab
mgattalla
Community Member
hi all ,
i will start with 642-587 AWLANFE
wlan exam
could any one tell me what the AP needed with this exam and any other devices will needed
is there any simulations
regards
m.sir
Level 11
Level 11
I used cisco aironet 1239 or you can use newer 1242 i suggest also PC with ACS 4.0 (free trial can be downloaded) with Certificate authority installed (I used MS server 2003)
M.
