Per client bandwidth calculation help
istvan.kelemen1
Level 3
Level 3
Assuming that "Air Time Fairness" is on, how can I calculate the real bandwidth per AP per channel?
Let's say we are on 5Ghz. Channel for N is set to 40Mhz, for AC is set to 80Mhz. GI is set to short.
4 clients are associated at 877.5Mb/s, 5 clients are associated at 450Mb/s and 7 clients are associated at 300Mb/s.
What would be the maximum per client throughput when all the devices are talkin at the same time?
How to calculate it?
Thanks you,
István
Philip D'Ath
Meraki Community All-Star
Well, there are 16 clients attached.  Maximum per-client bandwidth would be achieved if 15 of those connected were silent and did not generate or send traffic.  The maximum throughput would happen on the "best" connected  client.
So I would say the maximum per client bandwidth in this case would be 877.5Mb/s.
I have a theory.
Let's assume that max 5G rate may be 1300Mb/s and 2.4 may be 216.7Mb/s.
In this case the real BW would be 650Mb/s and 108Mb/s respectively.
So the max BW what AP would require may be 758Mb/s when the clients are associated at the highest speed, regardless of the number of the clients.
Let's take a real word example, assuming Airtime fairness is enabled.
For simplicity, let's say all the clients transmit for 1 second in a round-robin fashion.
Case 1, mixed clients:
5Ghz:
Client 1 : 1300Mb/s associated rate - 650Mb is sent
Client 2 : 877Mb/s associated rate - 438Mb is sent
Client 3 : 780Mb/s associated rate - 390Mb is sent
Client 4 : 292Mb/s associated rate - 146Mb is sent
Average speed in 4 seconds is: 406Mb/s
2.4G
Client 5 : 216Mb/s associated rate - 108Mb is sent
Client 6 : 144Mb/s associated rate - 72Mb is sent
Client 7 : 72Mb/s associated rate - 36Mb is sent
Average speed in 4 seconds is: 72Mb/s
Total AP average BW: 478Mb/s
Case 2:
5Ghz:
Client 2 : 1300Mb/s associated rate - 650Mb is sent
Client 3 : 1300Mb/s associated rate - 650Mb is sent
Client 4 : 1300Mb/s associated rate - 650Mb is sent
AVG: 650Mb/s
2.4G
Client 6 : 216Mb/s associated rate - 108Mb is sent
Client 7 : 216Mb/s associated rate - 108Mb is sent
AVG: 108 Mb/s
Total: 758Mb/s
Let's add few more slow clients:
5Ghz:
Client 5 : 292Mb/s associated rate - 146Mb is sent
Client 6 : 292Mb/s associated rate - 146Mb is sent
Client 7 : 292Mb/s associated rate - 146Mb is sent
Average speed in 4 seconds is: 294Mb/s
So my conclusion is that slower clients slow down all the faster clients which are connected to the same AP Radio in a directly proportional fashion.
Am I correct?
Philip D'Ath
Yes, you are correct.
Apologies on hijacking the thread as its been some time. I am curious and wondering on how the values are dervied? Is there a methodology/forumul for it?
Appeciate for the help 🙂
