Performance problem with AP1200
csco10143007
Community Member
I'm working at an international company and my order was to install an wlan solution at our office in japan with around 25 employes. One AP1200 with two antennas.
The problem is, that we need for transfer a file off 8,2Mb from server to client over AP1200 around a minute average. I'm still shure that you agree with me that's not the performance what we can expect from this equipment.
Second problem ist that the clients complain about several timeouts. at the logs I can see that clients lose there authentication.
Here is what I've configured and I hope that someone can help me!
express set-up
configuration server protocol: static ip
radio 802.11g
role in radio network: access point root
optimized radio network for troughput
aironet exstensions disabled
express security
SSID no broadcast SSID in beacon
VLAN no vlan configured
security static WEP Key; Key 1, 128 bit
SSID table
SSID xxxxxx
VLAN none
Encryption wep mandatory
Authentication shared
Ley Management none
network map
network map disabled
adjacent nodes no entires
network interfaces: radio0-802.11g:settings
enable radio enable
role in radio network access point root (fallback to radio island)
data rates best troughput
CCK Transmitter Power (mW): max
OFDM Transmitter Power (mW): max
Limit Client Power (mW): max
default radio channel: 1-2412 Mhz
world mode multi-domain operations dot11d
country code japan, indoor
radio preamble short
receive antenna diversity
transmit antenna diversity
external antenna config enabled; antenna gain(dB): 128
aironet extensions: disabled
Ethernet Encapsulation Transform: RFC1042
Reliable Multicast to WGB: Disable
Public Secure Packet Forwarding: Disable
Short Slot-Time: Enable
beacon period: 100
max.data retries 64
fragmentation threshold 2346
data beacon rate 2
rts max.retries 64
rts treshold 2312
repeater parent ap timeout
security: encryption manager
encyription mode wep encryption mandatory
encryption keys 4 x 128 bit
broadcast key rotation interval disabled
security: ssid manager
vlan none
authentication settings shared authentication; with mac authentication
server priorities
EAP use defaults
MAC auth use defaults
auth key mgr none
server manager
no radius or tacas server configured
security: advanced security
MAC auth local list only
local mac address list all allowed mac addresses
security: advanced security-timers
client holdoff time: disabled
radio-802.11g auth EAP or MAC reauthentication interval; enabled every 10 seconds
EAP client timeout 65555
TKIP MIC failure holdoff time: disabled holdoff
security: association access list
filter client associoation with MAC ACL none
services
telnet/ssh enabled
cdp disabled
filters disabled
qos disabled
ntp enabled
arp cachaing enabled
hot standby disabled
dns enabled
http enabled
snmp enabled
vlan disabled
wireless services AP
participate is SWAN infrastructure disabled
WDS discovery auto discovery
wireless services wds: server groups
use group for infrastructure authentication
ssid setting apply to all ssids
wireless services wds:general set-up
nothing enabled
system software
Product/Model Number: AIR-AP1231G-A-K9
System Software Filename: c1200-k9w7-tar.123-2.JA
System Software Version: 12.3(2)JA
Bootloader Version: 12.2(8)JA
Every hint to save this problem is recommend! Thanks for your assitance!!!
Peter Burggasser
will.shaw
Level 4
Level 4
Firstly, running 25 users on one AP, although possible I would recommend using at least two for this setup, both for load balancing and failover.
You should probably look at changing the following config:
Maybe increase the re-authentication interval to about 5 minutes, and change the EAP client timeout to about 30 mins not 18 hours.
It might be worth converting to the IOS image as well.
What client adaptors are you using?
we are using ibm thinkpad x40 (2371-8EU) 14 times and 5 fix based workstations. But at network flow it's calculated up to 25 users per AP.They are only working with office 2003 and SAP.
Today I've take a look on the clients. What I've seen was as follows. At the fix based clients they have a responce time around 1-3ms so it's perfect. But at the IBM side the limits of variation is about 20-350ms. That mean that you would need for an 8.55mb file for downloading about 1,2 minutes fomr the server. So I'm still shure that you can agree we with me, that doesn't fit. But at first thanks for your help!
Which client adaptors are you using?
Is there any way you could test the download whilst there are no users on the AP?
Yes of course. During the time shift I can observe this network at my daily business hours. The test results, during the time where nobody was on the AP show us the same as with coworkers on there. Maybe around 10ms better.
So the next step for me is to move all users to the old AP340 back again, build a lab and test this with other cards. Maybe its necessary to remove the build in wireless antenna from IBM and try an pcmcia card that may fits better to the AP.
What I can't understand is that all users are within a radius of 5-12 meters and it doens't work. Everybody have sight contact to the AP. The performance and espacially the result of this project is a nightmare! To get save we bought a second antenna. You can believe me to get this isn't so easy as in europe or in the staates to get this in Tokyo. Actuall situation is that domestic cards (PCI) at the desktops do there job much better as the more expansive cards from IBM.
Is this another way to bind customers to there own products? I don't know, but it looks like for me! Everbody talk about WIFI standard and everybody talk about the same but it looks that everbody cooks there own soup.
