phone can't connect wifi
marco6039291
hi all,
I get 2 WLC and serveral AP
here is the info
WLC: AIR-CT2504-35K9
AP: AIR-CAP26021TK9
here is the problem,
I set the WLC and upload the config , can ping the wlc and in the gui "wireless"can see ap
PC can get the wifi but the cellphone get the wifi about 3 mins and it will lose connect until off wifi and reconnect again ( but still will happen in 3 mins )
both apple and  android have this issue
how can i fix it?
thanks for help
ammahend
does this happen, when these phones roam, or this happens even if they are still at one location ?
Is this a new deployment or existing ?
when was the issue first seen ?
any change in network before you started experiencing this issue ?
whats the controller code ?
collect upload debug client <mac address>  (try to capture, client disconnect and re connection)
take any one iphone and one android mac address and upload this output.
-hope this helps-
hi ammahend
These device all are in one location
and these wlc is exist not the new one
originaaly, there are two wlc (called wlc01 and wlc02)
then client said wlc01 failed so i set the backup (called backup01)
and everything is work
when wlc01 RMA back , download config back and set back
in that day everything is work
but after 2 days , client responded that they cant connect WIFI with phone but pc can use wifi
so replace back backup01 but still cant solved it
here is some log
thank  u for ur help
This is not complete debug however on error
Source member:0.0.0.0. source member unknown.
refer to this blog, this might help.
https://supportforums.cisco.com/discussion/11075731/error-logs-wlc
If possible, do a complete capture - turn both devices off, start debug, turn them on, connect to network and keep is connected until they disconnect, connect them again.
**rate helpful posts**
-hope this helps-
hi ammahend
thank u for ur help
finally found is FW some failover command lost
key in back the command then wifi is working
thank u again
