PI / WLC Question - Controller Web UI Launch
Mo52
Visitor
We are using Prime Infrastructure 3.1.0.  Our organization has 11 WLCs listed in PI and only 10 of them are showing the option to Launch the Controller Web UI as a redirect from PI itself (shows little blue monitor icon next to ip address of WLC).  I cannot find the configuration setting which makes that option appear for our last WLC.  Anyone have this problem before?  Any advice?  Many thanks!
Ric Beeching
Level 11
Level 11
What WLC hardware/software are you using on each? Is the missing WLC a different model/software version?
Ric
Please rate helpful / correct posts
