pl help: EAP-TTLS configuration
srihari_rgda
Community Member
hi,
if any one had implemented EAP-TTLS as secuirty between clients and wireless devices, then pl help me in configring. And what are the security devices required
Srihari
7 Replies 7
pradeepde
Level 11
Level 11
The following document will help you in configuring EAP-TLS on your environment.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a008009256b.shtml
I did this but deos not work,
Does any one have further documents,
Do you want to configure EAP-TLS or EAP-TTLS?
Both are different.
If EAP-TLS, then what is the radius server, and have you configured client certificates on clients?
What is the error logs do you get on Authentication server?
That will give you right direction.
Prem
Thanks for giving a response,
I want to configure EAP-TTLS, and i have radius server as Cisco ACS. If you have any procedural document for configuring EAP-TTLS, could you please share.
Srihari
Dear Prem,
We had allready implemented PEAP but we have a new requirement that we have to install EAP-TTLS.
what is hte next alternative for this solution and EAP -TTLS is more secured then EAP-TLS (PEAP).
srihari
Hi Srihari,
This will give you a good idea,
MS PEAP vs. EAP-TTLS:
http://seclists.org/basics/2005/Feb/0032.html
http://www.cwnp.com/phpBB2/viewtopic.php?p=900&
EAP-TLS vs. EAP-TTLS:
http://www1.ietf.org/mail-archive/web/ietf/current/msg39667.html
EAp-TLS is what I'll go for, but its takes more planning, and more components.
Prem
