DHCP not issuing IPs to Wireless Clients
cobbc
Using hte following configuration, I can connect and authenticate. I can also configure the IP address manually and ping the gateway 10.205.2.1. I''ve pasted the configuration. What am I doing wrong?
i suspect it might have something to do with the ip helper address on the vlan interface and the dot11 radio interface.
cisco(config)#int vlan 1
cisco(config-if)#no ip help
cisco(config-if)#no ip helper-address
cisco(config-if)#int bv1
cisco(config-if)#int dot 0
cisco(config-if)#^Z
cisco#wr
then I did a reload. Still no IP assigned.
No answer?
