Placement and Location of Access Points
steveaudus
We are just starting a new build on our school, included on this is the installation of wireless over the top of our existing network.
I have read that cisco and other vendors supply free software to automate the placements of wireless access points, but I can't find it anywhere?
Any ideas or advice?
Steve Audus
Chaucer School
Sheffield UK
dixho
Level 6
Level 6
WLSE can help you to adjust the radio coverage. However, WLSE is not free.
We usually recommend you to hire a third party vendor to do a site survey. The vendor will take various antennas with them. They put different antennas in different positions; so that it gives you the best coverage. Finally, the vendor will give you a blue print and tell you the placement of APs/antennas.
manjeets
Level 3
Level 3
