Please how to reset password for AIR-CAP3702E-E-K9 ?
Tomas82
i try pressing mode button and reconnect but password recovery menu via console dont run
9 Replies 9
Ric Beeching
Level 7
Level 7
Just confirming you are doing the following:
  1. Power off
  2. Holding mode button, power AP on
  3. Continue holding for ~20 seconds until LED turns solid red
  4. Release mode button
  5. Power cycle once more as normal and wait for boot
  6. Login with Cisco/Cisco
Please rate helpful / correct posts
led flashing red but ip adress not work my home ip is 192.168.1.1 and copy from console is
DEAdeLT_ROUTER=192.168.1.1
DEFAULT_ROUTER=10.0.0.1
ENABLE_BREAK=yes
IP_ADDR=10.0.0.1
IP_addr=192.168.1.22
MANUAL_BOOT=no
NETMASK=255.255.255.224
RELOAD_REASON=41
TERMLINES=0
ip=192.168.1.22
ip_addr=192.168.1.22
netmask=255.255.255.0
Ohh you're stuck in rommon mode now. The AP has an IOS right? If you power cycle will it boot into the proper IOS?
Ric
Good day ,
I bought the AP for home.
AP is used and I do not know my name or my password and it's either in autonomous or lightweight.
would you ask me to help?
I took console cable.
Right can you do a flash_init and a dir flash: to see if there is an IOS on there? If not you'll need to get one from Cisco if you have support or err.. find one if you don't. You want one of these images:
https://software.cisco.com/download/release.html?mdfid=285029865&softwareid=284180979&release=15.2.4-JB3a&flowid=48542
Ric
%Error opening tftp://255.255.255.255/ap3g2-k9w7-tar.default (connection timed out)ap: flash_init
Initializing Flash...
...The flash is already initialized.
ap: dir flash
unable to stat flash/: permission denied
ap: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
tftp[5]: (read-only)
ap: unable to stat flash/: permission denied
ap:
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 15 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 6159872
flashfs[0]: Bytes available: 34998784
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: ec:bd:1d:a4:20:08
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entr y point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Montserrat Board
40MB format
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 19-Feb-15 10:27 by prod_rel_team
Montserrat Board
40MB format
Initializing flashfs...
flashfs[2]: 15 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 6159872
flashfs[2]: Bytes available: 34740736
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702E-E-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FCZ1937Y0HH
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.115.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: EC:BD:1D:A4:20:08
Part Number : 73-15397-01
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC19324D9H
Top Assembly Part Number : 068-05055-06
Top Assembly Serial Number : FCZ1937Y0HH
Top Revision Number : A0
Product/Model Number : AIR-CAP3702E-E-K9
% Please define a domain-name first.
ipv6 enable
% Invalid input detected at '^' marker.
ipv6 address autoconfig
ipv6 address dhcp
Press RETURN to get started!
*Mar 1 00:00:13.083: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:13.131: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:13.139: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:15.199: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.335: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:15.515: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:15.659: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:16.431: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:20.315: DPAA Initialization Complete
*Mar 1 00:00:20.315: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:21.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:23.315: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:24.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:27.435: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:28.435: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:30.811: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.22, mask 255.255.255.0, hostname APecbd.1da4.2008
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:34.203: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
%Error opening flash:/capwap-saved-config (No such file or directory)
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.1.1)
is it possible to send me the firmware to my email? and is possible to fix my ap via teamviewer ? thank you!
ap: tar -xtract tftp://192.168.1.17/ap3g2-k9w7-tar.152-4.JB3a.tar flash
extracting info (289 bytes)flash/info: permission denied
