Pocket PC wireless adapters
jfermo
Community Member
What PDA wireless adapters would you recommend that works well with Cisco 1200 AP. Security includes TKIP+WEP128 and Network EAP. Thanks.
vmoopeung
Level 11
Level 11
This depends on which model of PDA are you using, which band you are planning to work a,b,g. Most of the cards work with these specfications.
jfermo
Community Member
iPAQ PDA. Cisco AP is 1200 802.11G.
