PoE Power injector 802.3at and 802.3af
muki30001
I do not know if this is the right forum to ask this question
I'm trying to find technical specs of AIR-PWRINJ4
I received Power injector Model 740-64214-001 of Ruckus Wireless
That's the only thing I've found on Google on Power injector Model  740-64214-001
I want to know if its specification is the same as that of Cisco AIR-PWRINJ4
i have AIR-CAP3502 that work on Standard power supply
I want to use the Ruckus Wireless Power injector instead of the Regular power supply
Will this fit Cisco's AIR-CAP3502?
27 Replies 27
it is not controller based
it is standalone / autonomous
If I change the power settings
Just to try
Could it do some damage to the access point?
No, not as far as I know.
Here you find some information (at least for the older AP models): https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap4-first.html#25045
I saw that link It says
Using a Power Injector
If you use a power injector to provide power to the 1040, 1130, 1140, 1240, 1250, or 1260 access point, select Power Injector on the System Software: System Configuration page and enter the MAC address of the switch port to which the access point is connected.
There is no option to select power injector
only Pre-standard Compatibility and Power Negotiation
I read the manual of the access point
And I did not find any information about it
That's the most detailed thing I've found
It's not clear what I'm supposed to choose
and how do i find the switch port mac address ?
Sorry I don't have any more information about PoE than that.
Regarding the mac address, if it's a Cisco Catalyst
#sh int g1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is bcf1.f29e.d881 (bia bcf1.f29e.d881)
it is a cisco switch model SG200-26 26-Port Gigabit Smart Switch
i use his gui not command line
about the Access point
Could it be that the heat is due to the incorrect setting of the transmission power
Last night I was in a place where there were quite a number of such access points
None of them was hot
Are these settings correct?
I set it to a lower one
The access point is still hot
Is there anything else to do?
No idea why it gets hot, but I recommend you to use the CLI for configuration.
The switch supports 802.3af, so it's a current version of PoE and not a pre-standard one.
Which setting did you set to a lower one?
In any case, I wouldn't worry to much if it's running.
First of all, thanks to everyone who responded and help
I did not understand the answer
It is a switch without PoE
Those at an access point
It is less hot but still hot
(I've attached a picture of the settings at an access point)
What is the difference between the top line and the bottom line?
Ah sorry, misread SG200-24P (which would offer PoE).
Those two lines on your image are the sending and suggested receiving power for the radius interface. Not 100% sure about the Client Power, but the Transmit Power is the signal strength of the AP signal. 17 dBm is roughly 100 mW with the standard or built-in antenna (could also be 50, depending on the country). Anyway, that is only radio and is a tiny fraction of the full power usage.
Until now I was sure I had reduced the power of transmission
After reading some online Power Transmission 3500 data sheet
I think I did the opposite
I'm not sure any of this.
Transmitter Power (dBm):  was on 5
i set it to 8
According to the information page The higher the number, the higher the signal strength
So why on the other side where the low number is listed "max"
What parameters do I need to mark so that the transmission power will be the lowest ?
Are the other settings on the page OK ? (Autonomous-AP that is connected to the router using a network cable)
8 would be the lowest setting, 1 the highest.
Check the information in this thread for understanding the power levels and dBm:
https://supportforums.cisco.com/t5/getting-started-with-wireless/access-point-power-levels/td-p/1467363
It was on 8 and it was warmer
Now it's about 14 that's less hot
why on the side that there is the lowest number is listed "max" ??
It is not clear
As far as I remember, Client Power means what signal strength the client should use for communicating. The more power, the more battery drain of the mobile client.
But I agree, it would make more sense if the word "max" would be listed on the left and not right side of the table.
