point to point Bridge on Cisco Aironet 1310G
Hi Guys,
Is any one can help me to configure basic Point-toPoint wireless bridge.
I need to connect two simple LAN with Cisco Aironet1310 AP. I required basic configuration with basic authentication between these two devices which is on IOS "123-8.JEA3".
Cheers,
Par
16 Replies 16
Stephen Rodriguez
For T&E basics you just need to set a SSID and encryption
Dot11 SSID bridge
Authentication open
Authentication key WPA
WPA ASCII
Infrastructure-SSID
Interface dot11radio0
Encryption mode cipher trip
SSID bridge
That on both sides should get you up and running.
If you need to pass multiple VLAN you just need to add sub-interfaces to the radio and fastethernet interfaces
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks Steve for reply,
here is my configuration on root and non-root
==============ROOT Bridge==================================
dot11 ssid test
   authentication open
   infrastructure-ssid
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
==============NON-ROOT==========================================
dot11 ssid test
   authentication open
   mbssid guest-mode
   infrastructure-ssid optional
bridge irb
no ip address
no ip route-cache
ssid test
channel 2462
station-role non-root bridge
bridge-group 1
This is my basic configuration and its still not working.
I got syslog message "
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response"
Cheers,
Par
Stephen Rodriguez
If you are going to set the channel on the non root like that you need to same on the root as well.
Steve
HTH,
Steve
Yeah , I have removed the channel but still got same error.
Cheers,
Par
Here is the configuration:
ROOT:
no aaa new-model
dot11 ssid test
   authentication open
username Cisco password 7 0802455D0A16
bridge irb
no ip address
no ip route-cache
ssid test
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.10.10.1 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
NON ROOT:
no aaa new-model
dot11 ssid test
   authentication open
   infrastructure-ssid
username Cisco password 7 072C285F4D06
bridge irb
no ip address
no ip route-cache
ssid test
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.10.10.2 255.255.255.0
no ip route-cache
ip http server
control-plane
bridge 1 route ip
When I restart the interface dot11Radio 0 on non-root WAP, I got message:
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Cheers,
Par
Reset is the mode the non-root for into when it can't see a parent.
How far apart are these bridges? If thy are close to each other you may need to turn the power down, so that they are not 'screaming' at each other.
Steve
HTH,
Steve
I have four option for power, which one should I change, and should I changeon both side ?
Cheers,
Par
Set the CCK and OFDM power to 1. that should help
HTH,
Steve
HTH,
Steve
Hi Steve,
Changed the CCk,OFDM to 1 and still not talk to each other. I assume that issue comes from IOS version ,whats your idea ? do you wanna change the IOS to the latest version?
upgrading IOS, but still got no response. link still down !!!!!
Are these 1310, or 1310-R?  the -R is an external antenna that you need to connect up.
HTH,
Steve
HTH,
Steve
Yeah, they are AIR-BR1310G-A-K9-R with latest version of IOS "c1310-k9w7-tar.124-21a.JY"
And dumb question but the antenna is connected yes?
Steve
HTH,
Steve
No ,I dont have antena at all
