Policy does not Pushed To AP
sergey.dibrov
iseHello Team.
We have C9800 with Wave 2 AP in flex mode.
We are trying to implement SGACL enforsment for local switched traffic.
I see SXP connection with ISE. But SGACL enforsment doest work.
But in C9800 GUI in AP page, trustsec tab i see that  (screenshot  attached )  Policy does not Pushed To AP.
I see SGACL has been  downloaded to WLC:
wlc-test#show cts rbacl
CTS RBACL Policy
RBACL IP Version Supported: IPv4 & IPv6
  name   = Permit IP-00
  IP protocol version = IPV4, IPV6
  refcnt = 2
  flag   = 0xC1000000
  stale  = FALSE
  RBACL ACEs:
    permit ip
  name   = BLOCK-01
  refcnt = 3
  flag   = 0x40000000
  stale  = FALSE
  RBACL ACEs:
    deny ip any any
I see SGT tags has been  downloaded to WLC:
wlc-test#show cts role-based sgt-map all
Active IPv4-SGT Bindings Information
IP Address              SGT     Source
10.64.110.2             2       INTERNAL
10.64.128.6             11      SXP
10.64.128.194           2       INTERNAL
10.86.224.16            17      LOCAL
I have configured CTS policy in flex profile.
Form WLC:
wlc-test#show wireless cts
Local Mode CTS Configuration
Policy Profile Name SGACL Enforcement Inline-Tagging Default-Sgt
SM-CORP DISABLED DISABLED 0
SM-IPSK ENABLED DISABLED 0
SM-OPEN DISABLED DISABLED 0
SM-GUEST ENABLED ENABLED 0
SM-OPEN2 DISABLED DISABLED 0
default-policy-profile DISABLED DISABLED 0
Flex Mode CTS Configuration
Flex Profile Name SGACL Enforcement Inline-Tagging
TEST ENABLED DISABLED
default-flex-profile DISABLED DISABLED
I need to block traffic from SGT 17 to SGT 6 by applying SGACL on AP.
marce1000
                       Check if any of the mentioned restrictions could affect your case
 - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-1/config-guide/b_wl_17_11_cg/cisco-trustsec.html#id_85935
                            Guidelines and Restrictions
  • SGACL enforcement is carried out on the controller for local mode.
  • SGACL enforcement is carried out on an AP for flex-mode APs performing local switching.
  • SGACL enforcement for wireless clients is carried out either on the upstream switch or on the border gateway in a Branch-to-DC scenario.
  • SGACL enforcement is not supported for non-IP or IP broadcast or multicast traffic.
  • Per-WLAN SGT assignment is not supported.
  • SGACL enforcement is not carried out for control-plane traffic between an AP and the wireless controller (for upstream or from upstream traffic).
  • Non-static SGACL configurations are supported only for dynamic SGACL policies received from ISE.
  • Static SGACL configuration on an AP is not supported.
 M.
