PORT CHANNEL ISSUE
khurram1987
i have WLC 4400 series and i have configured port channel its four ports with my core.problem is when i apply port chanel on it it turns down and core log shows that
extende: %EC-SP-5-CANNOT_BUNDLE2: Gi2/6 is not compatible with Po5 and will be suspended (vlan mask is different
my mode on core is auto and in wlc its also auto
can you please solve my problem..
thanks
Leo Laohoo
Post the config of PO5 as well as the config of Gi2/6.
Scott Fella
The mode should be 'ON'
channel-group 5 mode on
Ethernet load balancing should be src-dst-ip
show etherchannel load-balance
port-channel load-balance src-dst-ip
-Scott
Fella thanks for your suggestion ...tell me what mode should be on WLC...??
current is AUTO....
On WLC, just enable LAG.
on the switch, as Scott said.
