Ports to be opened for Radius communication between WLC and ISE
vijay kumar
Level 2
Level 2
Hi all,
My anchor controller is placed after the firewall . Inside zone ISE has been installed. So for any radius communication between ISE and WLC , ports such as 1812 and 1813 should i need to allow ?
TS.
Jatin Katyal
Yes they need to be opened on the firewall for radius communication. (UDP 1812- authentication and UDP 1813 - accounting.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
5 Replies 5
Jatin Katyal
~BR
Jatin Katyal
~Jatin
Hi Jatin ,
thanks for your reply . We are building the new same setup  as below in the doc ,
http://www.cisco.com/en/US/docs/solutions/Enterprise/Borderless_Networks/Smart_Business_Architecture/February2012/SBA_Ent_BN_BYOD-GuestWirelessAccessDeploymentGuide-February2012.pdf
But it is not mentioned to open the ports of 1812 , 1813 except port number 8443 for web auth.
Kindly confirm on this...
Hi Vijay,
I guess you missed it
Look down under the same document page 11, step 11.
~BR
Jatin Katyal
~Jatin
yes , i missed it . Thanks Jatin.
Your Welcome !!!
~BR
Jatin Katyal
~Jatin
