Power Injector Compatible with 541n AP
paulo_rosa
Hi. Can you please confirm if the Cisco Power Injector (AIR-PWRINJ3=) is compatible with the 541n AP ? I find info about compatility with other AP models but didn't find any related with this SMB model. If isn't compatible can you please suggest another Cisco model or I must use a third party model ?
sudkulka
Any 802.3af capable power injector should work for AP541N. However, AIR-PWRINJ3 is not supported with AP541N.
Thanks for the info. Some time after I put the post I discovered that. The AIR-PWRINJ4 is 802.3af and can be used. I also discovered a topic somewhere on this forum with a comment of a Cisco Tecnhical saying that Cisco doesn't support any model of power injector with SMB products (Cisco models including). Great Comment ! Great Support !
