Power Management
iromero
Community Member
We have WCS 5.2.130.0
Access points are LAP1131AG
The parameters for every radio are managed via templates.
Power is assigned dynamically.
Load Threshold:
  Max client=12.
The problem that we have is that sometimes AP's accept as twice as the maximum number of clients on one radio and none on the other.
How can I force the AP to balance the load?
dancampb
Level 11
Level 11
The max client load threshold does not limit the number of clients that can associate to the AP.  I will log an alert when that threshold has been exceeded so that you can determine if changes need to be made.  Currently there is not a way to limit the number of associations per AP.
