Power setting for Cisco 1200
bob.schwartz
On the RadioG settings :
CCK Transmitter Power (mW): 100 Max
OFDM Transmitter Power (mW): 30 Max
what is the difference between setting it to Max or to 30 or 100?
They would both seem to be the max.
dixho
Level 6
Level 6
CCK is used by 802.11b. OFDM is used by 802.11g. As 802.11g is backward compatible with 802.11b, you can set both transmit power on 802.11b and 802.11g packet.
Ok, but my question is what is the difference between setting them to 30 and max?
30 would seem to be max
I am sorry that I misunderstood your question. Max gives you the maximum allowed in the country of the opeartion. If you are in US, 30 and the max are the same. If you are in different country, max gives you a different value. Please see the URL below for more information:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i12215ja/i12215cr/cr15main.htm#wp2459838
