Power Supply
scascitelli
Community Member
I received some Access Point AIR-AP1230B-E-K9 from my distributor ESPRINET ( in Italy ) but , not received the power supply . It is correct ?
Thank for your answere
Rob Huffman
Hi Enzo,
The AP1230 should ship with the local power supply (as indicated below). If you need Power Injectors on the other hand, they must be ordered seperatly;
The Cisco Aironet 1230AG Series Access Point is a dual-radio 802.11a and 802.11g access point that provides the versatility, high capacity, and enterprise-class features demanded by wireless LAN customers. The mini-PCI interface supports the 802.11g radio that operates in the 2.4 GHz frequency band, while the CardBus interface supports an IEEE 802.11a radio module operating in the 5 GHz frequency band. This access point may only be ordered as a preconfigured bundle, which includes the access point platform in addition to both 802.11a and 802.11g radio modules. Selection of a country power cord is required, and options for an inline power injector and console cable are available through the Cisco Configuration Tool.
The Cisco Aironet 1230AG Series may be ordered with Cisco IOS Software to operate as an autonomous AP or with Lightweight Access Point Protocol (LWAPP). When the 1230AG is operating as a lightweight AP a WLAN controller is required. When ordering the access point, the software image version must be selected in the configuration option. At the completion of configuration, the product will arrive fully assembled.
The Cisco Aironet 1230AG Series platform is the basic electronic chassis of the access point. It is configured with both 802.11a and 802.11g radios. Each access point ships with a 110-220 VAC local power supply, and is available with Cisco IOS Software.
Cisco Aironet 1230AG Series access points may be powered with the local power supply ***included with the access point, or by using powering equipment capable of providing Cisco inline power over Ethernet, such as Cisco Aironet power injectors or Cisco inline powered switches and routers.
From this ordering Guide;
http://www.cisco.com/en/US/products/ps6108/products_data_sheet0900aecd801b9266.html
Hope this helps!
Rob
