Power to 521 Access Points
Kevin Melton
Level 2
Level 2
I am trying to Power a Cisco 521 AP from a blade on a 4500 switch. The blade module number is WS-X4548-GB-RJ45V. This is supposed to be a POE blade, but when I plug the AP in, I do not get the AP to power up.
5 Replies 5
Leo Laohoo
What is the IOS you are currently running? What is your Supervisor card?
Check the ports. See if "power inline never" is on the config.
thanks for the response. It is actually configured for :power inline auto: on the port.
But it shows a status of :off:
Check your cable.
I have tried using 2 different ethernet cables. Neither power up.
Not familiar with this AP but are you sure you are plugging it into the FE port and not the console port?
