10-03-2017 10:41 PM - edited 07-05-2021 07:42 AM
I need to know the difference between power options for Cisco 1852I
Which one is better and why ?
Farhan.
10-03-2017 10:54 PM
Hi Farhan,
As far as AP functionality is concerned, there are no advantages/disadvantages to using either one. Both provide full power to the AP.
AIR-PWRINJ6= -> An injector supplies power through the network cable to a device that is POE capable.
AIR-PWR-C= -> An adapter is just something that lets you power a normal (non PoE) device.
same kind of posts here: https://supportforums.cisco.com/t5/getting-started-with-wireless/power-injector-vs-local-power-supply/td-p/1174040
Dont forget to arte helpful posts
10-03-2017 10:59 PM
AIR-PWR-C is a power brick.
- AIR-PWRINJ6=
- AIR-PWR-C=
Farhan.
AIR-PWRINJ6 is an injector.
Use the power brick if the power outlet is near where the AP is deployed. Otherwise, use the injector.
10-03-2017 11:17 PM
I was configuring on CCW and came to know that they both (Injector and Power Supply) require Power Cable to power up if I am correct.
Can you please clarify this ?
Please see the below link.
10-03-2017 11:22 PM
Yes both will need power cable.
