Prime Infrastructure 2.0 and add a WLC device
alex.roth
One question regarding to add a device / WLC Controller  into NCS 2.0. I done this in the past with NCS 1.3 without problems
but now I don´t know why but if I add a device into the NCS 2.0  I get the the message CLI Failure /  timeout.
I doublechecked all on the controller but I don´t see any failure . For my understanding I have to add a user under"Local Managmeent User " and then add this credentials into  the Telnet/SSH Parameters on the NCS 2.0 .
Thanks for help.
9 Replies 9
Scott Fella
Are you entering the SNMP v2 string in read write?
-Scott
I added SNMP v3 credentials with passwords.
Cheers
Well the default encryption on the WLC's are different from the PI 2.0 default.  Make sure that matches and when you created the SNMPv3, make sure you reboot the WLC as that is required.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott,
WLC reboot is NOT required when configuring SNMPv3, it was a documentation error in the config guide. See below
https://supportforums.cisco.com/thread/2214836
Alex:
Here is an WLC CLI method to config a SNMPv3 users (example used admin & Cisco123Cisco123). Try in this way & see (you should be able to correct it using GUI as well, but this is easy via CLI)
(WLC) >config snmp v3user create admin rw hmacsha aescfb128 Cisco123Cisco123 Cisco123Cisco123
Rasika
**** Pls rate all useful responses *****
Scott Fella
Well when I changed the password, it didn't work until I rebooted. Also it warns you that you need to reboot. So who knows:)
-Scott
Hi Scott,
Upto 7.3 config guide it was documented we have to reboot WLC when we configuring SNMP v3 which is wrong. (here is 7.3 config guide link for reference). May be older version (prior to 7.0) had that requirement, not too sure about it
http://www.cisco.com/en/US/docs/wireless/controller/7.3/configuration/guide/b_wlc-cg_chapter_0100.html#d16741e4514a1635
From 7.4 onwards config guide does not talk about it all. I deleted the default SNMPv3 user & create a new user in 7.4 & add it to prime without rebooting WLC.
Once you configureed a SNMPv3 user on a WLC, I do no think you can edit/change the password. You have to delete the user & recreate it with modified username/password.Then re-add the WLC to prime
The behaviour you mentioned is with any of later codes  of WLC ?
Rasika
I will test it again. I'm running v7.6
-Scott
alex.roth
Sorry for my late response. I fixed the problem as I inserted a snmp 2 string into the PI 2 and also I created on our
tacacs server a special user for CLI access to use this   together with PI 2.0 for device management.
Cheers
Kuat Bakenov
my ERORR:
"CLI Failure: A timeout occurred when trying to communicate with the device."
i use snmp v3.
but need check connect via ssh other client.
(added admin user to wlc, but ssh not work.) i used default installation username ......
