Prime infrastructure display issues
Vincent Duprez
Frequent Visitor
Frequent Visitor
dear all,
I have some display problems with Prime 1.3 .. and the same with 1.2 🙂
for example the Discover Devices doesn't display the menu where I can click to launch the quick discovery.It's the case in classic theme but not in lifecycle theme.
It happens with IE with Chrome frame, with firefox and Chrome ..
any idea?
Attached the print screen and what it is supposed to be !!!
thanks in advance,
regards,
vincent
Scott Fella
Could be a cosmetic bug. Mine works okay on PI 1.3. Maybe try another computer and see or else open a TAC case so maybe they can tell you if it's a known bug or file a new bug case.
-Scott
Here is my PI 1.3
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
