07-30-2015 05:04 AM - edited 07-05-2021 03:39 AM
Hi.
Has anyone of you encountred the message:
VOIP Call Failed for "(Error Code 15) occurred on client "xx:xx:xx:xx:xx:xx' which was associated to AP <APName> on interface 802.11b/g?
The client is using a 7921 wireless handset and she's complaining that sometimes when she makes a call, the phone displays "leaving service area". This does not happen all the time, it happens intermittently on the user.
Your comments related to this issue is appreciated. Thanks.
Ken
07-30-2015 05:56 AM
What type of access points ?
what code is the phones on ?
How often does this happen ?
07-31-2015 04:33 PM
make sure the data rates configured like below :
1)for 802.11a :
12.0 should mandatroy , higher data rates supported and the lower should be disabled .
2)for 802.11bg:
11.0 should be mandatory , higher data rates supported and the lower should be disabled
Beers
Ali
07-14-2016 03:01 PM
I'm also having this issue for one of our clients.
Well not in Prime but the 7921G phone intermittently showing leaving service area
Client has a 2504 controller with 1832 access points
I have tried 8.1.131 and 8.2.100 code but not making any difference
07-14-2016 06:23 PM
The status message, "Leaving Service Area" indicates that the phone is not receiving a strong signal.
07-14-2016 11:31 PM
Thanks mohanak I have looked at these already. But this is happening while standing under an AP. Without roaming with very good RSSI and SNR or moving between AP's
I read somewhere that continuous scan should be set on the CUCM, is that a default?
