Prime Infrastructure with Mesh Networks
scottsassin
My customer has a Mesh network at a sea port.  They have about 15 mesh access points at each location with two controllers each.  Would Prime Infrastructure work with a mesh deployment?  There is a lot of interference and sometimes the performance of the network is affected.  I want to use the WCS portion of Prime, to manage the mesh coverage, parent/child relationship between the RAP's and MAP's.
Please let me know if Prime is something I can suggest to my customer to ease the management of the mesh network.
Scott
George Stefanick
Hi Scott
Prime is the replacement for wcs. Wcs isn't supported past code 7.0.
