Prime (NCS) for WLAN
a-weitzel
I should make an offer for a client "Prime (NCS)" for its wireless environment
I must admit that I do not look through despite a long search at Cisco.
Current is apparently the Preime (NCS) Release 2.0. When I look at wireless, but I find only release 1.1?
The customer has a WLC 5508 SSO cluster, 3600, and 1242 APs.
What Rrelease can I take and what I need for the WLAN Management and possibly also for Netflow?
Can I use Prime for the VoIP environment (Call Manger and phones) too?
Can you give me some explanation and the right URLs?
Thanks for your support.
cheers Alexander
Saurav Lodh
Level 7
Level 7
Surely you can use Prime infra. for your Voip environment as well. You  can monitor Voip calls graphs/statistics etc. PFA for the supported  devices for each of versions 2.0, 1.4, 1.3 and 1.2 . You can use the excel sheets for future use to know the devices and software compatiblity!
