priority setting in ap's
marodrig
Community Member
I have 6 meraki MR46 ap's these are distributed in the company but we are having the problem since there are devices that do not connect to the closest ap, is there any way to move clients between ap's or some configuration so that it is done automatically?
ww^
Meraki Community All-Star
https://documentation.meraki.com/MR/Other_Topics/Client_Balancing
At some client wifi drivers you can also tweak roaming aggressiveness
You could also look at your wifi desing/ lowering transmit power if they currently have to much overlap https://documentation.meraki.com/MR/Radio_Settings/Transmit_Power_and_Antenna_Configuration
ww^
marodrig
Community Member
thanks for the answer and support
happy new year @jdb1 @alessandrodematos
aleabrahao
As @jdb1 said you can try to change some configurations, but remember that roaming is a client decision.
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/Client_roaming_and_connectivity_decisions_explained#:~:text=Roaming%20is%20a%20client%20side,APs%20advertising%20the%20preferred%20SSID.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
