problem access point : as client wierless
Dhikra Marghli
Level 9
Level 9
Hello ,
i have a problem that acces point 1 as a client wilress : have role mobile, desctop ...
So why ap has this role ???????, how i can allow as a point access normal !!
thanks
7 Accepted Solutions
Dhikra Marghli
Level 9
Level 9
the problem that access point is getting internet connection as a wiresles client ?????,,
so how i can resolve this problem !!
thanks in advance
Sandeep Choudhary
 did you configure AP as workgroup bridge ?
and the same configuraton as others AP
i don't understant why only this AP get internet  !! not as other AP !!
please , how i can resolve this problem !!
i compared  all AP with this AP1 but AP1 is always get internet as a mobile , desctop ..
so what i can do that allow AP as other AP 😞  fortigate 200 D is show in interface this sitauation )
i need a help urgent
1. reboot the AP
2. Check the AP is in local mode or not
and last check if AP is in correct AP group!
Dont forget to rate helpful post
Please, check some configs in your AP.
1.Check if they are at the same group.
2. Check if your aps is online your controller.
3. Check if the correct vlan is allowed in your ap.
Jaderson Pessoa
*** Rate All Helpful Responses ***
8 Replies 8
Dhikra Marghli
Level 9
Level 9
thanks in advance
Jaderson Pessoa
Sandeep Choudhary
1. reboot the AP
Did you can solve the problem?
Jaderson Pessoa
