Problem after upgrading from 7.0.116.0 to 7.2.111.3
We have upgraded 2 of our 5 controllers to 7.2.111.3 but after the upgrade we get ssl-error on our web-auth ssid that use a local netuser. We tried to reinstall the certificate on the controller and it started working but stopped again after 10 min. We have alsot tried reinstalling the web-auth bundle but no luck.
We get ip-address and the PC indicates that it has internet connection but when we open the browser the ssl problem pops up. After some troubleshooting we moved beyond the ssl problem(we havent solved the problem) and now get this when we open a browser.
http://portal.zzzz.xx/fs/customwebauth/hotellespinternet.html?switch_url=http://portal.zzzzz.xx/login.html&ap_mac=10:8c:cf:b5:a6:d0&client_mac=f0:7b:cb:67:8a:2d&wlan=Hotell-Esplanad&redirect=portal.zzzz.xx/fs/customwebauth/hotellespinternet.html?swit...
porta.zzz.xx is the dns name we use for our web redirects.
hotellespinternet.html is the web-auth html page
We have removed the dhcp proxy function on the controller. We have alsot tried with one of our other web-auth pages and that didnt help either.
Anyone having any suggestions on how we can solve this?
Scott Fella
Did you double check the configuration on the WLC?  Are you anchoring, if so, make sure the mobility is up.  Also, did you upload the FUS image since you went to 7.2?  This is required.
https://supportforums.cisco.com/docs/DOC-23757
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Michael Burk
Joakim,
Did you ever find a resolution to this issue?
Also can you post what WLC model you are using for others who are interested in using the code version but depend heavily on the guest wireless feature?
