Problem Airprint with Standalone AP1602
lukas.braendle
We have 2 Standalone AP1602. They works great with perfect coverage. However, we have the Problem that we cannot print from our IOS Devices over Airprint. With the old Linksys APs this works, but after we implement the new APs Airprint did not work again. We see the Printer on the Print Dialog and can print without Error on the Device. However, nothing happens on the Printer. There is also no Error in the Log file.
We hope that someone of you can give us a hint how we bring Airprint work again.
Thanks for the help!
Scott Fella
Others have ran into bonjour issues with autonomous and it seems like disabling igmp snooping in the AP fixes most but not all. Give that a try and see.
-Scott
Scott Fella
-Scott
Hello Scott,
Thank you very much for your input. I will try to disable the igmp snooping on the AP. I hope this works.
I give you a Feedback when i tested this.
Best regards
Lukas
Hello Scott,
I disabled the igmp snooping on the AP. Now Airprint works again. Thank you very much! :-)
Best regards
Lukas
No problem. Can you mark the questioned answered. It helps when others search the forums. Thanks
-Scott
