Problem between WLC and Radius
Marco Aresu
Level 2
Level 2
i am getting some problema with Wireless authentication. When i create a wireless account to the Radius server using LDAP the maximum users that can will use this account is almost 25.
Is there any limit to set on WLC or Radius Server?
A workaround for this issue is to create a LocalNetUser on the WLC but is not a good solution (i suppose)
WLC model 5500
Marco
7 Replies 7
maldehne
can u calrify what do you mean by "maximum users that can will use this account is almost 25"
maximum 25 (almost) person at the same time can use the account X (create on LDAP directory) for authentication in the wireless network.
once reach this "limit" they get error while try to authenticated.
But when i create the same account X locally on the WLC we didn't get any issue.
security  --> aaa --> user login policies
Max Concurrent Logins for a user name , what is the value ?
Pleae make sure to rate correct answers
the value is 0 (unlimited)
ok so this is why for internal users it is ok.
for LDAP as far as i know there is no limit,
but the question is what is the type of security used ?
can u share :
show advanced eap
show sysinfo
i found something about "maximum concurrent login" for radius.
below the output request:
(Cisco Controller) >show advanced eap
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.101.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name......................................
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address.......................................
Last Reset....................................... Power on reset
System Up Time................................... 4 days 2 hrs 9 mins 23 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
Configured Country...............................
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
--More-- or (q)uit
Internal Temperature............................. +40 C
External Temperature............................. +28 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 707
Burned-in MAC Address............................
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 250
can you please collect the following debugs when you try to exceed 25 logins for the same user:
debug client  < mac address of the wireless client >
debug aaa all enable
Please make sure to rate correct answers
