WLC 5508 with IPAD IPOD IPHONE and Landing page not appear
Patrick Werner
Hi Community.
We have a centralized WLC with some branch office with AP's in Flexconnect Mode. The Wlans are configured to use Web Authentication (Landing Page). The Landing Page is Cisco Default.
We're experiencing some problem with Apple Devices, on some the Landing Page apperars on some not. The WLC Software is about 1 year old.
On a XP machine the landing page doesn't appear too, but you can type in the address manually and it works.
Whats the best sollution to include the Apple Devices successfully in the WLC Wireless World.
Hope you can help, Patrick
9 Replies 9
Scott Fella
Well what address are you using to see the WebAuth page, your virtual? Usually the issue with a WebAuth page not showing up is DNS issue or the user trying to access an https site as their home page.
-Scott
Patrick Werner
The Branchoffices has a Router with DHCP for the Wireless devices who connects to the Internet, we have created a Vlan with a dedicated DHCP range.
Here is the Router config:
ip dhcp pool BlueMonkeyGast
network 172.16.80.0 255.255.254.0
default-router 172.16.80.1
dns-server 8.8.8.8
ip dhcp pool BlueMonkeyEvent
network 172.17.80.0 255.255.254.0
default-router 172.17.80.1
dns-server 8.8.8.8
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.80.9 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface GigabitEthernet0/0.2
encapsulation dot1Q 180
ip address 172.16.80.1 255.255.254.0
ip access-group BlueMonkey in
ip nat inside
interface GigabitEthernet0/0.3
encapsulation dot1Q 181
ip address 172.17.80.1 255.255.254.0
ip nat inside
interface GigabitEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside source list ACL_NAT interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 192.168.10.0 255.255.255.0 192.168.80.1
ip access-list extended ACL_NAT
permit ip 172.16.0.0 0.15.255.255 any
ip access-list extended BlueMonkey
permit udp any any eq bootps
permit udp any any eq bootpc
deny   ip any 172.16.0.0 0.15.255.255
deny   ip any 192.168.0.0 0.0.255.255
deny   ip any 10.0.0.0 0.255.255.255
permit ip 172.16.80.0 0.0.0.254 any
permit ip 172.17.80.0 0.0.0.254 any
Address is 1.1.1.1
Scott Fella
Have you verified that DNS is working? I know your using a public address, but no splash page is a DNS issue as long as the client gets an IP.
-Scott
To test if the landing page works and eliminating the WLC side is to open a browser to the VIP address. So if you get the landing page using the VIP, then it's most likely a network issue or DNS. Verify connectivity using a laptop connected to the guest vlan and verify the laptop gets an IP and can access the Internet.
-Scott
Just to add to what Scott stated. If you have specified a DNS name on the Virtual Interface then the DNS server must resolve that name to the virtual interface IP address of 1.1.1.1. The DHCP scopes are using the public DNS server 8.8.8.8 (Google) which will not work.
Bill Jenkins
Guys, i see every second IP adress has a Internet connection. Every even IP Number, the odd IP Number havent a Internet Connection
I do a NAT betwenn 192.168.0.14 255.255.255.0 and 172.17.20.1 255.255.254.0
This is my NAT Rule
Here the NAT Translations:
tcp 192.168.0.14:51174    172.17.20.2:51174     4.28.11.50:443        4.28.11.50:443
tcp 192.168.0.14:53590    172.17.20.4:53590     17.149.36.177:443     17.149.36.177:443
tcp 192.168.0.14:50095    172.17.20.6:50095     17.172.232.70:443     17.172.232.70:443
tcp 192.168.0.14:49391    172.17.20.8:49391     17.172.232.114:443    17.172.232.114:443
udp 192.168.0.14:55348    172.17.20.8:55348     8.8.8.8:53            8.8.8.8:53
tcp 192.168.0.14:52477    172.17.20.10:52477    157.56.254.54:443     157.56.254.54:443
tcp 192.168.0.14:34352    172.17.20.12:34352    212.227.17.186:993    212.227.17.186:993
tcp 192.168.0.14:56589    172.17.20.20:56589    17.158.10.36:443      17.158.10.36:443
the web auth certificate installed on your controller is it locally generated or third party
what is the CN?
If it is CN doesn't equal 1.1.1.1 i would go with
The problem was in the ACL. If the wireless client hasn't a connection to the internet, the landing page doesn't appear.
Thanks guys
